Soft patch
woolf1975
Soft patch
Beitrag von woolf1975 »
Can You please implement soft patch in program. In theatre lightning soft patch is very important thing. I know that Your program is based on devices , but I would like to patch chanels and devices, for example I would like that channel 1 open dimmer channel 34,56,123. If it's possible it would be great. Thanks in advance, great job so well and sorry for my bad english :D
Re: Soft patch
Hi woolf1975,
this is already possible. Click on the tab "Settings" and go into the Data-In-Setup. There you can create a softpatch as you have described: channel 1 can control channel 34, 56 and 123 at the same time.
cu,
Chris :)
woolf1975
Re: Soft patch
And now officialy, Your program is perfect :D
