Hi, I have tried to use my Enttec Pro Mk2 DMX to drive 2 universes, however although the setup says it is working I have been unable to get it to drive universe 2. This works ok with q-light controller software and seems ok with 1 universe. Any suggestions?
Thanks
Enttec DMX 2 driver
Re: Enttec DMX 2 driver
Thank you very much for the report. I've found the problem: the header-definitions I've used for the plugin seem to be wrong. I've found an updated version of the definitions and will recompile the plugin.
The next version of the PC_DIMMER will be available within the next days.
kind regards,
kind regards,
Thank you for the very prompt support for a great program. If you need a beta tester for anything I am more than happy to help.
Hi, just to let you know I tried 5.4.1 Build 4650 from 12.28.2015 which still does not appear to work correctly with the Enttec DMX 2.
Thanks
Thanks
OK, next try. Here is another new version of the plugin.
I've used the Header-Information for port 2 that Enttec has written in there documentation - not within the examples. The documentation was more recent than the examples - maybe the examples were not up to date.
kind regards,
kind regards,
enttec_promk2_dmx.zip- (355.94 KiB) 464-mal heruntergeladen
