USB-uDMW512
Philippe Bontemps
USB-uDMW512
Beitrag von Philippe Bontemps » 26.04.2016, 16:02
Hello,
My project do not function ; is it possible that it's the adaptator which is not goodly installed ?
I join the files of install for this hardware and 2 print screen
I have copied the dll (uDMX_PcDimm.dll) in pc_dimmer\plugins\
Can you help me for a good use of PC_DIMMER ?
friendly Yours
Philippe
X-uDMX512_manual.zip
(9.94 MiB) 83-mal heruntergeladen
ecran pc dimmer.pdf
(371.75 KiB) 80-mal heruntergeladen
Philippe Bontemps
Re: USB-uDMW512
Beitrag von Philippe Bontemps » 28.04.2016, 23:48
Hello all is OK !
The problem was on the settings to "Disable driver signature enforcement" for windows10
At this url you'll find all you need to install the driver : http://blog.ricohansen.dk/Lists/Posts/Post.aspx?ID=45
and at this URL : https://www.illutzmination.de/fileadmin ... Driver.zip you will find the drivers for this adaptator USB DMX 512 that I buy at aliexpress for only 15 € !!!
I hope that this post will be a great help for the users of PC_DIMMER , a great software for light control !
Friendly
Philippe
