Enttec DMX 2 driver
Verfasst: 24.12.2015, 22:51
von an1j21
Hi, I have tried to use my Enttec Pro Mk2 DMX to drive 2 universes, however although the setup says it is working I have been unable to get it to drive universe 2. This works ok with q-light controller software and seems ok with 1 universe. Any suggestions?
Thanks
Re: Enttec DMX 2 driver
Verfasst: 25.12.2015, 14:00
Thank you very much for the report. I've found the problem: the header-definitions I've used for the plugin seem to be wrong. I've found an updated version of the definitions and will recompile the plugin.
The next version of the PC_DIMMER will be available within the next days.
kind regards,
Verfasst: 26.12.2015, 12:36
von an1j21
Thank you for the very prompt support for a great program. If you need a beta tester for anything I am more than happy to help.
Verfasst: 28.12.2015, 23:25
von an1j21
Hi, just to let you know I tried 5.4.1 Build 4650 from 12.28.2015 which still does not appear to work correctly with the Enttec DMX 2.
Thanks
Verfasst: 29.12.2015, 00:37
OK, next try. Here is another new version of the plugin.
I've used the Header-Information for port 2 that Enttec has written in there documentation - not within the examples. The documentation was more recent than the examples - maybe the examples were not up to date.
kind regards,
