Position calibration - not working or I don't understand?
Verfasst: 13.09.2011, 14:08
Hello,
I can't get position calibration work for any device
..Maybe I don't understand the purpose of it or it is not working...Build 5.0.9 4401 and also 4402 (same situation).
Step 1: I create some project, put into it one device (eg some scanner) with PAN and TILT channels (in DDF editor those channels are really of type PAN and TILT).
Step 2: Select that device in "Devicecontrol window", click Calibrate button and create a calibration zone on the right side, for example only into a very small square in the middle, not whole area as it was before. The preview works ok.
Step 3: Back to Devicecontrol , set on the device that new created calibration zone (in the combo box).
My expectations: Now I would expect...if I create a moving scene OR an effect altering PAN/TILT of this device OR if I move the pan/tilt position of that device on the panel on Sidebar...pan/tilt values to be converted (in my example if I create a moving scene with circular movent, this calibrated scanner would move it's mirrory only in a small angle in the middle and it will never reach it's corners.
Reality: Scanner uses it's whole angle, does not respect calibration in any way.
What am I doing wrong?
I tried multiple DDFs, multiple situations..all resulting the same...
