Hello all,
does anyone know how to create the link between PC_DIMMER and DMXControl?
I downloaded this Plugin:
http://www.pcdimmer.de/phpBB3/download/file.php?id=67
but I do not know how to start it in PC_DIMMER.
Thanks for the help
Bridge between PC_DIMMER and DMXControl
Re: Bridge between PC_DIMMER and DMXControl
you need the PC_DIMMER Plugin "DMXControl Bridge" as well. With this Plugin, you can connect to DMXControl (with activated "PC_DIMMER Bridge"). When I will be back at home, I will upload the plugin for you.
cu,
cu,
I have already downloaded the file "PC_DIMMER_Bridge.dll" and put it in Plugins folder of DMXControl.
When you put the link, where I have to put the file "DMXControl_Bridge.dll" for PC_DIMMER?
How do I load it into PC_DIMMER?
Thanks so much for the help.
I have much need to make this connection between the two software.
here are the plugins for DMXControl and PC_DIMMER. Please do following things:
For DMXControl:
1. Download the following file: http://www.pcdimmer.de/phpBB3/download/file.php?id=67
2. Extract the DLL out of this ZIP-file and move it to C:\Program Files\DMXControl\Plugins\
3. Start DMXControl and open the Pluginsetup (mainmenu -> "Configuration" -> "Plugins...")
4. Activate the PC_DIMMER-Bridge Plugin
For PC_DIMMER:
1. Download the attached file to this post
2. Extract the DLL out of this ZIP-file and move it to C:\Program Files\PHOENIXstudios\PC_DIMMER\Plugins\
3. Start PC_DIMMER and go into the Advanced Options
4. Activate the DMXControl Bridge-Plugin
5. click on "Configure" and do a Search for the DMXControl Window
6. If the DMXControl-Window has been found go to the DMXControl Pluginsetup-Screen and click on configure here, too.
7. Do a search for the PC_DIMMER window
That's it. Now you can change a value within PC_DIMMER or DMXControl and each program will send the values to the opposite.
cu,
For DMXControl:
For PC_DIMMER:
cu,
dmxcontrol_bridge.zip
- (218.83 KiB) 365-mal heruntergeladen
Thank you,
in PC_DIMMER works. Changing the value of a channel in PC_DIMMER also varies DMXControl.
In DMXControl I copy the file "PC_DIMMER_Bridge.dll" in "C: \ Program Files (x86) \ DMXControl" but on the "Output plugins ..." there is no the inscription "PC_DIMMER-Bridge".
Therefore varied a channel of DMXControl does not change anything in PC_DIMMER.
You can also send me a file "PC_DIMMER-Bridge.dll" to work?
maybe I do not understand the problem, but you've copied the file "PC_DIMMER_Bridge.dll"... why do you need this file again?
You can download the DMXControl-Plugin (which is called "PC_DIMMER_Bridge.dll") from here: http://www.pcdimmer.de/phpBB3/download/file.php?id=67
And I made a mistake: you do not have to copy the "PC_DIMMER_Bridge.dll" into the mainfolder of DMXControl, but into the following folder: C:\Program Files\DMXControl\Plugins\
Then you will find the Entry "PC_DIMMER Bridge" in the mainmenu of DMXcontrol under "Configuration" -> "Plugins..." (not "Outputplugins...".
