Hello chris
In the last beta version, on the faderpanel, the support on the sideline ALT works but does not bring to light the keys of this group (in blue before). For the key CTRL, it still belongs OK
thank you for this new version
I still work on the translation
bye
fred
ALT KEY b5.0.0.4000
Re: ALT KEY b5.0.0.4000
Hi Fred,
thank you for this information. I will fix this in the next update.
have a nice Sunday in advent,
hello chris
it's ok in the 5.0.0.4005 version
red group whith Ctrl key, blue group with Shift, green with ? and with the Alt key is there a color ? group with Alt key is ok but i can't see them
bye
fred
bye
fred
OK,
to see all of the highlighted functions a device has to be installed on the channel of the faderpanel. The colors are as following:
CTRL-Key: RED-Colored channelnumber on top
SHIFT-Key: BLUE-Colored channelname of installed device on the bottom of the panel
ALT-Key: GREEN-Colored devicename
this is not the best solution - I know - but it was very easy to program
do you have an idea for a better solution? Please let me know...
bye,
bye,
Hello chris
Thank you for colors and their explanation, it is very well as it
But I think that if we could attribute a letter to the channels of a fixture and to press this letter at the same time as we move one of the fader of the group it would allow not to be restricted to 3 groups
Is it good idea?
thank a lot
bye
fred
Is it good idea?
thank a lot
bye
fred
Yes, this would be possible, but it is much easier to use he submasters for this function. The faderpanel is only for changing single channels. But the submasters allows to change multiple channels with one single fader.
À bientôt,
À bientôt,
hello chris
ok, no problème
thanks
fred
ok, no problème
thanks
fred
