PC DIMMER Arkaos Grandvj
Hi! I would like to know if it's possible to control Grandvj (or other vj software) over pc dimmer. It will be amazing if its possible. Honestly i think this is the best free dmx software you could grab. Much better then freestyler. Contratulations!
Re: PC DIMMER Arkaos Grandvj
there is no native support of any 3rd party control software like grandvj. But you could try to use MIDI to control GrandVJ and get feedback from it. You will need a midi loopback driver. Then, if you don't use any MIDI controller with grandVJ yet, you should be able to choose one and route it to the midi loopback driver. In PC_DIMMER, you also select the loopback device and set the properties to control. For the MIDI parameters, you can also see the arkaos user forum, there are also users that use MIDI to connect with other software.
Good luck,
Good luck,
